9 members (Nick in Manitou, Gray_Ghost, Shade Baby, J Lucas, TUTS 59, Bill Hanlon, papas52, 2 invisible),
120
2
Mod | | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30009 04/25/2005 12:10 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | I would recommend against using the chevy style oil filters since they don't have a bypass valve in the filter. The bypass valve is needed to allow oil to bypass the oil filter due to ecxcessive restriction such as cold oil. If you don't have a bypass valve you risk the inner tube of the filter collapsing and flushing filter media through your engine. The best is to use the ford/chrysler type of filter. The only gm style filter (that I know of) which incorporates both a bypass valve and the antidrain back valve is the NAPA 1072. The 1072 was designed for wisconcin engines and probably not readily available.
Jason
