I did pull over and check, and it's running clear. I drove it some more today and it only did it part of the time. Had a little bit of a backfire when starting out from first once, it's not done that before. I'm thinking maybe the carb might be set a bit too rich?
Not quite as lean
Not quite as mean, but
Still a Marine!
