| | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29469 06/01/2004 12:13 PM | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | Just a little tip that may help. If you have an old valve cover around that you don't care about, cut a whole large enough over each adjuster so a socket will fit through and put it on with a gasket for adjusting. Keeps most of the oil from spattering up your inner fenders and fire wall. The system you described is the one I use, but check your manual for proper back off turns. Could be anywhere from 1/2 to one full turn. Varies with engines. 3/4 is what I see most.
Truck Tinker | | |
