| | | Forums66 Topics128,132 Posts1,056,383 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28912 10/06/2002 1:46 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The breather on my 52 is a 1/4" pipe fitting with a groove cut in it and a piece of sheet metal crimped over it. You could take a close nipple and a cap, drill holes in the side of the cap near the top, or drill holes in the nipple. Holes need to be small to keep dirt out.
Try putting an ad in the swap meet, surely someone has one in a rear end the replaced. You could also try a salvage yard that has older vehicles, or give one of the on-line vendors a call. Jeff at Bowtie Bits probably has some.
Fred 52 3600 69 C-10
