7 members (Peggy M, Hotrod Lincoln, mason86, 1955 1 Series, Simon1954, 53again, Cosmo),
97
0
Mod | | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28724 03/17/2004 3:37 AM | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | You probably need to set your idling up or if you are running a performance cam, you need a stall converter. What it sounds like is you have too much load still on the transmission before the converter can start free-wheeling. Other than that, it sounds as if your carb is over-loading and flooding out and if that was the case, it would be hard to restart. Try setting your idle up a tad first.
Truck Tinker from Talking Rock, Ga. | | |
