2 members (Dennys28, 1 invisible),
93
Mod | | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28723 03/17/2004 2:48 AM | Joined: Jan 2003 Posts: 13 Member | | Member Joined: Jan 2003 Posts: 13 | i have a 51 3100 that i have fitted with a 78 305 tubo 350 and nova rear end my problem is stalling when returnig to idle after burnig the tires i have checked for vacum leaks tried the timing at 4 and 6 and 8 degrees nothing seem to help at all the weird thing is that it will restart without touching the gas pedal the carb is a neww edelbrock 600 any ideals ?? | | |
#28724 03/17/2004 3:37 AM | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | You probably need to set your idling up or if you are running a performance cam, you need a stall converter. What it sounds like is you have too much load still on the transmission before the converter can start free-wheeling. Other than that, it sounds as if your carb is over-loading and flooding out and if that was the case, it would be hard to restart. Try setting your idle up a tad first.
Truck Tinker from Talking Rock, Ga. | | |
#28725 03/17/2004 8:30 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You may want to add a dashpot to the carburator. It closes the throttle slowly on return to idle and allows the jets and manifold to clear of extra gas to prevent stalling. They are common on 4 and 6 cylinder automatic cars.
#28726 03/17/2004 11:03 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Give it 10* btdc and try increasing idle mixture. My LeMans does the same thing, because the idle circuits in the Qjet I'm using are emissions calibrated and won't provide enough fuel. Also check for fuel slosh in fuel bowl, choke adjustment, check manifold vacuum.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
