3 members (Nick in Manitou, Sjm, 1 invisible),
88
Mod | | | Forums66 Topics128,264 Posts1,058,356 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28497 04/01/2004 4:48 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Yup, typically need to pre-fill the converter with the correct type of tranny fluid. Amount depends on converter. Refer to converter mfg for information. Make sure you've got a good cooler, as stall converters can generate more heat than stock units. Make sure that converter bolt pattern, thread pitch and hub dimensions are correct for application.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
