yes Mitch, works fine - you can use the drums and hubs from the early car on the TaskForce truck spindles to get the 5 bolt - the early 5 bolt car rims also have the clips for the correct hub caps [6 clips for the earlier car, rather than the 3 on the TF truck 6 pin wheels] - bearings and brakes are the same too
