measuring in at 5'22" i think i may be able to help you.
1, unscrew your turn signal lever, put it into a vise and bend it just after the nut so that it is closer to the steering wheel.
2, if you replace your winsheild, replace it with a non-tinted one
3, if you replace your headliner, do not put the insulation back under it. . . every 1/2" counts.
4, if you replace your seat cover, take out as much padding as u can (note: this only works if you are a hard a$$ :p )
5, heat up your gear shift stick (or whatever it is called) shere it bends, and bend it away from you (tward the passanger), make sure that it still clears your seat/dash when u do this.
6, if it is add on blinkers (like my 49), you can put the blinker stick on the right hand side. This is because your left leg is trapped between the door and the steering wheel, while your right one (that only has to move far enough to gas and brake) can "lay over" and go between the gearshift and the wheel.
7, (while i have not done it) a tilt/TELESCOPE steering wheel would be nice
8, if your seat does not already *almost hit the back of the cab, make it so it does (in my 94 **** extended cab, it clears the back seat by 1" wink )
9, (i have thought about, but not done) lower the floorboards, just put a 3" body lift on the pickup, and leave the floor where it is at. :rolleyes:
10, go bye an IHC Scout, cuz u will fit in one of those :p (can i say that on here :rolleyes: )
BrianK
p.s. for all of u that say "see being tall must suck" just remember, i was your height one day, but i think i like being tall better.
You on the other hand will never know the "pleasures of being tall"
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
