The 3836848 head was used on 54-62 Chevy 235's, according to one source. You must have a Chevy 235 in your GMC (Canadian GMC's used Chevy engines). Check the right side of the block for other numbers: on pad to rear of distributor, over the starter, and down low up front by the fuel pump.
