| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26699 05/20/2004 5:59 AM | Joined: May 2004 Posts: 6 Junior Member | | Junior Member Joined: May 2004 Posts: 6 | I puchased a 59 chevy truck with an inline 6. I've read everything I can find but still don't know exactly which engine is in there? Here's the numbers I have found and their locations on the engine... Cylinder head: 3701887 Manifold: 3835590 Engine block (below distrib...towards front of engine): 3764476 Below distributor: GM 11 Small screw plate (above starter towards the distrib): D196
Also the valve cover has 2 bolts stickingup through the top to hold it down.. I know this indicates a older (pre 54) 235 but is it possible that an older valve cover could be bolted onto a new 235??? help??? | | |
