8 members (Otto Skorzeny, Steelonsteel, Gdads51, J Lucas, Peggy M, dt235sd, walter74, klhansen),
127
3
Mod | | | Forums66 Topics128,036 Posts1,055,454 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26497 07/24/2003 7:27 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Wayne, are we to understand that you are fabricating custom steering linkage and only need to keep the stock bits from the firewall to the wheel? If that's the case, I would suggest a pipecutter and patience to trim the outer tube. Once the tube is out of the way you can probably torch the shaft to length. | | |
