question for zachscc? what problems if any and rear end did you use for your muncie sm465 swap and if you don't mind me ask, what kind of expense was it? I have a 4speed in a 52 five window, 235 with patricks 3:55, works ok but I run about 3,000 rpm at 60, this conversion kit from patricks, bot transmission and ring/pinion is suspose to equal a muncie and good for up to
300 hp motor, unknown is that is true, Thanks for
your time.........Fred
