| | | Forums66 Topics128,167 Posts1,057,022 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | 216 - 302 motor it does not matter the ratios are below line up the columns to all 5 gears.
florida as well as kansas are better suited for a 3.08
CHEVROLET T-5 Borg Warner Transmission Ratios: 1st: 2.95 2nd: 1.94 3rd: 1.34 4th: 1 5th: 0.74 Tire Diameter 1: 28.5 inches Rear Gear Ratio 1: 3.08:1 MPH RPM 1st 2nd 3rd 4th 5th 6th 1000 9 14 20 26 36 0 1500 13 20 30 40 54 0 2000 18 27 39 53 71 0 2500 22 34 49 66 89 0 3000 27 41 59 79 107 0 3500 31 48 69 92 125 0 4000 36 54 79 106 143 0 4500 40 61 89 119 161 0 5000 45 68 99 132 179 0 5500 49 75 108 145 196 0 6000 54 82 118 159 214 0 6500 58 89 128 172 232 0 7000 63 95 138 185 250 0 7500 67 102 148 198 268 0 8000 72 109 158 211 286 0
Tire Diameter 2: 28.5 inches Rear Gear Ratio 2: 3.43:1 MPH RPM 1st 2nd 3rd 4th 5th 6th 1000 8 12 18 24 32 0 1500 12 18 27 36 48 0 2000 16 24 35 47 64 0 2500 20 31 44 59 80 0 3000 24 37 53 71 96 0 3500 28 43 62 83 112 0 4000 32 49 71 95 128 0 4500 36 55 80 107 144 0 5000 40 61 89 119 160 0 5500 44 67 97 131 176 0 6000 48 73 106 142 192 0 6500 52 80 115 154 208 0 7000 56 86 124 166 224 0 7500 60 92 133 178 241 0 8000 64 98 142 190 257 0
CHEVROLET T-5 Borg Warner Transmission Ratios: 1st: 2.95 2nd: 1.94 3rd: 1.34 4th: 1 5th: 0.74 Tire Diameter 1: 28.5 inches Rear Gear Ratio 1: 3.73:1 MPH RPM 1st 2nd 3rd 4th 5th 6th 1000 7 11 16 22 29 0 1500 11 17 24 33 44 0 2000 15 22 33 44 59 0 2500 18 28 41 55 74 0 3000 22 34 49 65 88 0 3500 26 39 57 76 103 0 4000 30 45 65 87 118 0 4500 33 51 73 98 133 0 5000 37 56 81 109 147 0 5500 41 62 90 120 162 0 6000 44 67 98 131 177 0 6500 48 73 106 142 192 0 7000 52 79 114 153 206 0 7500 55 84 122 164 221 0 8000 59 90 130 175 236 0
Tire Diameter 2: 28.5 inches Rear Gear Ratio 2: 4.11:1 MPH RPM 1st 2nd 3rd 4th 5th 6th 1000 7 10 15 20 27 0 1500 10 15 22 30 40 0 2000 13 20 30 40 54 0 2500 17 26 37 50 67 0 3000 20 31 44 59 80 0 3500 23 36 52 69 94 0 4000 27 41 59 79 107 0 4500 30 46 67 89 120 0 5000 34 51 74 99 134 0 5500 37 56 81 109 147 0 6000 40 61 89 119 161 0 6500 44 66 96 129 174 0 7000 47 71 103 139 187 0 7500 50 77 111 149 201 0 8000 54 82 118 158 214 0
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
