1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | If it is a 216 original engine it will have a large side valve cover that goes up around the spark plugs and two bolts in the top valve cover.
If it is a 235 of later venue it will havce a short side valve cover about 8" tall and four side bolts on the top valve cover. This could also be a 261 engine with these features.
If it's neither of these then do the numbers as referenced by others. | | |
