7 members (crenwelge, Hotrod Lincoln, delwrench, 2-Ton, Cletus1950, Jay R, Hugh63c10),
330
Mod | | | Forums66 Topics128,159 Posts1,057,027 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | John,
On the 1954 Suburban, the fuel line is part of the sending unit. I think that the Chevy Duty sending unit to which you refer is for a pickup gas tank (which is in the cab, behind the seat). I am almost certain that the 1953 Suburban sending unit is the same (just like the diagram in Sect. 8, Sheet 1).
Your tank might have been "adapted" at some time - most likely because the sending unit had to be replaced and no one sells a new replacement.
The anti-squeak between the tank and the support bars above the tank (not between the strap and the tank) looks like a thick roofing "tar-paper". I used strips of black vinyl but 3-4 layers of 30# roofing felt would do fine.
Tim | | |
