Buddy,
The front floor and toeboard are the same, except for the floor under the hinged passenger seat. The only difference I found is that my 1954 Suburban's location for the dimmer switch is different from the pick-up. The pick-up's location for the dimmer switch is a better location, and replacement wiring harnesses are matched to the pick-up's location.
Tim
