1 members (Peggy M),
131
2
Mod | | | Forums66 Topics128,105 Posts1,056,538 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 23 Apprentice | | Apprentice Joined: Sep 2006 Posts: 23 | Strat,
If you look in the Tech Tips under rear ends there is an article that gives the measurements of common replacement rear and also the original truck widths.
The '57 truck had a width of 62" flange to flange. Unless you are going to buy offset rims to compensate for the wider rear end, you will probably have some interference issues.
I specifically bought my posi rear end based on finding a 62" width so I could keep the interference issues to a minimum.
Good luck!
Carl
CCB
