1 members (Peggy M), 131 guests, and 2 robots.
Topics128,105
Posts1,056,538
Members48,448
#241086 09/20/2007 7:22 PM
Junior Member
Junior Member
I have a 98 camaro rear end that measures 65" from wheel mount to wheel mount. I have the box off the truck (57, 3100) and not going to have it mounted for a while yet. Does anyone know if the width of this axle, and a modest size tire fit in the fenders? I tend to second guess my self, too much.
With the best of regards,
Strat
My 1957 Chevy 3100
#241087 09/20/2007 9:31 PM
Apprentice
Apprentice
Strat,
If you look in the Tech Tips under rear ends there is an article that gives the measurements of common replacement rear and also the original truck widths.
The '57 truck had a width of 62" flange to flange. Unless you are going to buy offset rims to compensate for the wider rear end, you will probably have some interference issues.
I specifically bought my posi rear end based on finding a 62" width so I could keep the interference issues to a minimum.
Good luck!
Carl
CCB
