I've got a power steering pump, gear box, and brackets headed my way for my '72 C-10. The setup is from a 4WD so I believe I need to change the Pitman arm. No problem there. However, I've seen a number of steering column lower shafts (between the rag joint and the gear box) advertised on eBay as for "power steering" setups. Is there a difference in shafts between power and non-power steering and thus I'll need to buy one? My '72 is (obviously) non-power steering right now with a factory floor shift.
Brent
