| | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | I've got a power steering pump, gear box, and brackets headed my way for my '72 C-10. The setup is from a 4WD so I believe I need to change the Pitman arm. No problem there. However, I've seen a number of steering column lower shafts (between the rag joint and the gear box) advertised on eBay as for "power steering" setups. Is there a difference in shafts between power and non-power steering and thus I'll need to buy one? My '72 is (obviously) non-power steering right now with a factory floor shift.
Thanks, Brent | | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I'm pretty sure you gotta use 2wd stuff on 2wd. you can use a box up to 87 from 1/2 ton 2wds | | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | My question is about the steering shaft, whether there's a difference in the lower shaft between power and non-power. Not worried about the box itself. But thanks! :-) | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | steering shaft should be the same, the length is adjustable | | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Okay -- thanks! Wondered why some "power steering" lower shafts were for sale on eBay and wondering if there was really a difference. Thanks again! :-) | | |
