1 members (Thomaslb),
138
2
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | When I first had my truck there were rear coil overload springs on it. There was a bracket welded to the top of the axle both sides with a bolt projecting vertically. The springs are tapered, wider at the top and there was a plate on the bottom with a hole for the bolt to go thru. A nut kept them in place. I have seen leaf overload springs but never coil. It could be some after-market item but the way the bracket is mounted to the axle it appears to be original. It is a Canadian built truck. Anyone seen these? | | |
