2 members (DaveV, Napco Man),
99
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#23689 03/06/2005 2:53 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | I just finished changing the cam in my 54 mod. 235. Hot Rod is correct check and make sure there is an oil gallery at the lifters.(some blocks were designed for solid lifters and the oil gallery was not used)and use the proper (new)lifters for the cam used. It is nessary to remove the grill and radiator to get the cam out. You will also need to remove the oil pan to get to the bottom bolts on the timeing gear cover. This is not a hard job just time consuming. Good luck | | |
