Would reversing the springs help? The reason I ask, 3100's have the spring pin off-center because the axle pivots behind the spring mount. 3600 axles arehard-mounted to the springs, so wouldn't the pin be in the middle?
Good luck.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
