I'd go with what Bill said since working with one piece is easier but you can use the small freeze plugs like go in the end of an oil galley. Drill a hole in the center, usually a 3/16 and put it on with the concave side over the shoulder of the ornament stud. If you include the lock washer that's 3 pieces and a little trickier to start.
Evan
