7 members (Shaffer's1950, David Bush, Hotrod Lincoln, JW51, Gdads51, Gray_Ghost, Gib70),
107
0
Mod | | | Forums66 Topics128,051 Posts1,055,735 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | Lee... we had the same issue with ours (also from CPP). Instead of drilling holes we used the the 2 opposite holes. It was definitly a pain to line up. When we called we got the exact same answer you did.
I am still having probs with the back drums. They lock up if you step on the brakes too fast. One of these days we will get that bug worked out. The push rod seems to be too long because the pedal engages too far back.
The front disk kit that we got from them had no issues at all. Make sure you bench bleed it first. We didnt and it took forever to get all the air out..lol. Had to take it all off again and do it right.
Good luck. I dont know much but I hope I helped a little.
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | |
