The driver's side window regulator won't budge.
I can see the scissor mechanism wiggling a bit, but it won't lower the window..
This is on my '64. I was going to remove the regulator screws, then decided to ask here before breaking the glass.
How should I approach pulling the mechanism out? The regulator shaft has excessive play in it. Are there bushings available, or should I plan to turn one? Better to buy a regulator? LMC Truck?
Thanks!
CJ
