Im installing a 87 C10 tilt column and booster/master cylinder pedal assambly in my 51 3100 and im having problems, the pedal shaft is rubbing the column,I ran the column thru the same opening as the old column and installed the pedal assambly bracket in place of the old dash bracket, has anyone ever done this before if so do you have any pictures or know of any ? I cant figure this out ! HELP
