Quote
Originally posted by olblu49:
A bit off topic but to keep mice and rats out of your truck while its in storage or awaiting restoration, put in a few handfuls of moth balls. That will keep them away.
Dryer sheets keep the mice away, too.. and won't stink up your truck as bad as moth balls.. but you have to change them regularly.
Once the smell wears off the dryer sheets, the mice will come back, and end up using the sheets for bedding.
an idea is only stupid if you think about it rationally.
