| | | Forums66 Topics128,130 Posts1,056,720 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | The regulators are different shape and size and there is a vertical forward edge track that is part of the vent window frame, inside the door. This would have to come out. The sheet metal on the sill of the doors is different with the vent window door because of a tab which holds the vent window latch. The inside window frames are slightly different as there is a notch cut out of the vent window model frame. Of course the glass is different. IMHO it would be easier to change the whole door if you have access to them. | | |
