Jim,
Go to ebay and put this number into the search locator: 120069092720
That is the piece you need to hold on the hood at the rear. It mounts with 2 bolts. You put the two pieces/halves of the hood together and then slide it into this piece in the rear. Then, you attach the 'bullnose' piece on the front and that secures the hood.
ALSO, when you post, it will 'appear' where ever you put the address.
Timmer
