Yeah Brian, I did grind off a little of the clamp at the meeting surfaces but it still did not work. And I was afraid if I ground down too much I would end up with pinches on either side of the tube or worse, the tube would oval out. But as you said, nothing to loose in trying it again.
1948 AD Pickup
