I live near Grumpy's and went over there to look at them before I bought them. I liked them so I bought them. I ended up doing the right floor / toe board / right lower outer and inner cowl. Left back cab corner / lower left outer cowl. All of the pieces fit great. A couple of words of advice ...
1. Cut the patch panel to fit the area you are going to replace.
2. If you do the outer cowls. Make sure that you maintain the correct dimension across the door. I didn't and now I have to cut them back out.
