7 members (MickeyP, Rusted Nut, Steelonsteel, 5 Window 9434, Dennys28, Southerntruck, mick53),
91
3
Mod | | | Forums66 Topics128,043 Posts1,055,612 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | Jim - very little advice on trying to make a tripower work on a small block (we would have advised using dual quads).
Best I can tell you is think of the tripower as a four barrel with remote secondaries. In other words, block off the outer two and attempt to calibrate the center for idle and high vacuum. Then attempt to calibrate the outer two for WOT.
An exhaust gas analyzer would be a wonderful help in calibration.
And still the best advice I can give is replace it with a dual quad.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
