did you unbolt it from the radiator support? or do you plan on taking that with the front clip.
theres about 4 or 5 bolts on each side, bolting the fenders to the rad support. or, just take the radiator out, and unbolt the rad support, that, coupled with the inner fender bolts, should let you get it all out.
i've messed with alot of fenders...bolts appear out of EVERYWHERE it seems.
good luck!
.later days.
.sam.
1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint.
doing it all myself.
19 and lovin' it.
"proper" is so over-rated.
.later days.
.sam.
