Answered my own question.
OK, if anyone else needs to know you will need a 2 and 1/4" hex socket, to turn the Worm Bering Adjuster Lock Nut. You can get one at Sears....(God I love Sears)...Also, It does not matter what you do with the wheels being on the ground or not once you disconnect the sector shaft from the pitman arm. Of course if you jack up the truck you will have more room to work...but I'm skinny..Oh, ya you will need a pitman arm puller...I'm not sure how to put the pitman arm back on yet. I'll let you know when I fugure it out.
I'll round off that bolt head....just as soon as I'm done strippin' this screw!
