| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20714 08/18/2003 11:24 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | don,
I have always set the timing to the timing mark (disconnect/plug the vacuum advance line as you state). I then set the carburetor by setting the idle speed to the desired rpm and then adjust the mixture screw at the maximum vacuum reading.
Sequence of tune-up operations:
1. Set points (if new, put in new condensor) 2. Set timing (after turning in the distributor lubricant "cup") 3. Set carburetor - set idle speed - set mixture to maximum vacuum (connect to wiper vacuum line) - recheck idle speed - recheck mixture 4. Recheck timing 5. Reconnect vacuum advance line 6. Cruise for burgers
This might seem redundant but it works.
Tim | | |
