2 members (NJC, baldeagle),
60
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19563 07/05/2004 4:36 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Run a wire from the B+ terminal on the choke element to the fuse block and hook it up to one of the terminals that say's Ignition. You can also test the terminal to be sure their is current only when the key is on and not also when it's in the accessory position. If it also has juice in the Acc position you WILL burn out the heating element in the choke.
Joe
