| | | Forums66 Topics128,099 Posts1,056,501 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 52 Member | | Member Joined: Jan 2005 Posts: 52 | When I did the brake job on my 46 1/2 ton I had the same problem on getting the left rear brake drum off as it was froze up. I used lot of pentrating oil and two large pry bars and a big hammer. When I got the drum off I found a broken brake spring which let the shoes stay in the brake position plus all of the huck linkage was siezed up. I replaced all brake shoes and springs and rebuilt all wheel cylinders. I also wire wheeled all the huck linlage and pins and used anti sieze when I put it back together. I also rebuilt the master cylinder and replaced all the brake lines and now I have good brakes. Jamo | | |
