| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | Mark,
I just had the same thing happen. On the passengers side on the top hinge the bottom left hand bolt would just spin. So I took the complete door off and used a chisel the knock the head off the bolt. I got lucky because I can reach the back of the nut through the heater opening.
On the drivers side the hinge pins worked their way partially out and I had the drive them all the way out before the hinges would come out.
All said this took me a couple of nights work just to get the hinges off.
Good Luck! Aaron | | |
