| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Greg - here\'s the layout - most folks have a cotter pin in the throttle linkage where there needs to be the special clip shown to hold the rod in place, and the cable goes thru the hole and is held by the little screw clamp so the linkage can move while the cable slides in the hole - when you pull the hand throttle it pulls up the linkage clear enuff? Bill | | |
