0 members (),
309
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18389 01/14/2002 7:10 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Go to a bearing shop with your dimensions and they may be able to look one up from that. I think your shaft is common 3/4" for center hole and measure housing ID for outer ID of bearing. I use Bearings Inc, here which has new name of Industrial ***** something now. You will probably have to slot the housing and pull tight with a clamp to hold it in place. Shouldn't need to be real heavy. Fords used a nylon thing in ends of theirs in 70's, that used to fall out after cab brackets went bad and cab fell on steering column! Don't know if they have similar dimensions or not. Try a bearing shop.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
