0 members (),
171
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18044 04/20/2002 1:41 PM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | Unless you are going to keep the truck for a show truck in complete original condition. I would suggest you replace the gas tank with one that is mounted underneath in the rear of your truck to the frame. Gas tanks inside of cabs are a huge saftey concern. Also this way you know you have a new clean tank and good to go.............
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
