| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18042 04/20/2002 12:57 AM | Joined: Apr 2002 Posts: 5 Member | | Member Joined: Apr 2002 Posts: 5 | I have the gas tank under the seat and the truck has not been started in ten years. Should I pull it out to clean or not before putting gas through it? | | |
#18043 04/20/2002 2:22 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | At the least, I would recommend draining the tank and cleaning the fuel filter. If you don't drain out any rust, it should be okay.
Fred 52 3600 69 C-10
#18044 04/20/2002 1:41 PM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | Unless you are going to keep the truck for a show truck in complete original condition. I would suggest you replace the gas tank with one that is mounted underneath in the rear of your truck to the frame. Gas tanks inside of cabs are a huge saftey concern. Also this way you know you have a new clean tank and good to go.............
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
