7 members (tclederman, Gdads51, 1955 1 Series, moparguy, Gray_Ghost, Otto Skorzeny, 1 invisible),
75
10
Mod | | | Forums66 Topics128,078 Posts1,056,027 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18041 02/09/2004 2:34 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Here's the poorman or thriftyman's way to remove the bushing with all credit going to fellow bolter Boyo. A whopping $3.50 from Home Depot. That's right a 3/8 x 6" carriage bolt, 3/4" gal pipe T fitting, 2-3 large washers and then 2-3 smaller washers followed by the nut (not the one holding the wrench). http://community.webshots.com/photo/96669114/105847828oKoSOB I highly recommend buying 2-3 bolts for all bushings because such tension will possible weaken the threads to the point that you might get a couple uses out of one bolt. Very effective.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
