2 members (David Bush, 52Carl),
115
9
Mod | | | Forums66 Topics128,078 Posts1,056,029 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, you will gain a small amount of torque, and better fuel economy. You could probably run a few degrees advanced with no trouble. Just advance it a bit at a time until it pings on grades on hot days and back it off a little bit. You will probably need to re-adjust the idle mixture and speed on the carburator after adjusting the timing for smooth idle.
