7 members (klhansen, Bills54, Steelonsteel, 2-Ton, stoveboltgator, dt235sd, TexasA&M48Truck),
119
2
Mod | | | Forums66 Topics128,047 Posts1,055,534 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17433 12/27/2001 12:56 PM | Joined: Dec 2001 Posts: 146 Member | | Member Joined: Dec 2001 Posts: 146 | Hi Sandcaster, The oil pressure sender is in the passenger side, below the lifter side cover, around the place where the cilinder number 5 is. Normally there is a dowel pin on the first and one in the last of the exhaust manifold holes. The studs or screws must be positioned in a way that allows the clamps that holds both manifolds to head to be placed according to the places that they atacches the manifolds. As for the wires, You'll have to get a multimeter and check what/where they are for or from. What ignition are You using, an HEI, or any other aftermarket kit??
Alexandre Garcia
