2 members (Peggy M, panic),
89
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17420 04/16/2005 4:25 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I would recommend that you do loosen the rear mounts (as per the manual) and when you are putting the front mount assembly in place you might consider doing what I did by applying some gasket goo around the hole where the bolt from the motor goes thru the cover plate. This will keep oil from a leaking timing cover from weeping thru. There is a new motor mount available which is not rubber (I forget but think it is some type of poly) and it won't rot ever. If you contact me I can find the address. Bill | | |
