Quote
Originally posted by Bullet:
If you just want it for originality thats fine but I had a 69 chevy half ton and the jack would'nt fit under the back axle if the tire was flat. I bought a one ton jack that has worked fine on every thing I have used it on for many years.
It wouldn't fit under the lower A on the front, either. Meant that if you really had a flat you better have a couple of 2x4 blocks handy. Jack where you can, block it up and jack some more.
Fred
52 3600
69 C-10
