From the chevytalk.com thread:
http://www.chevytalk.org/threads/sh...3&an=0&page=0&gonew=1#UNREAD Robert_May wrote:
You may have the wrong value in there. There is no 46x in the values. Try 360 ohms which is a 5$ value.
The colors on the resistors can be a bit tricky to determine. In addition, if the resistor is a 1$ value, there is an added digit to the value which means that there are 3 value bands and a multiplier vand. I don't remember all of the values of that system but I think that there isn't a 460 ohm value in that system of falues either.
hmn...
-W
